nmcharka's avatar
May 02, 2019
Can I use RBK53 with CBR/K 40?
I already have an Orbi RBK53 set up with a Fios modem; 1 router/sat and two identical satellites. I would like to replace my cable modem so i do not have to rent it from either XFinity or Fios; Can I add a CBK40 to the RBK 53 and eliminate the rental equipment?
My home is a very spread out rancher, over 6000SF but i am completely wired with CAT6 so i can wire my backhaul as well. I may need to add another satellite to my RBK53 set up anyway; but this would kill two birds with one stone if possible.
Is this doable?
  • plemans's avatar
    Yes and no.
    CBK isn't capable of fiber, it will do a cable connection.
    Also the base router's don't mix. If you add the cbk, you won't be able to use the rbr50 with it.  You can use the satellites interchangably but not the main routers. Sorry.
    • nmcharka's avatar
      nmcharka
      Guide
      Very help information. Thanks
      To be clear, I would remove the RBK53 and then I could add another RBR 50 and a CBK 40 modem unit; but I would have to use Xfinity (cable) and not Fios (fiber)?
      I appreciate the help greatly!
