krob3
Dec 21, 2019Aspirant
Can I use RBR20 router as a satelitte if I upgrade to RBR53?
I currently have the RBK23 and 2 satellites. Its a 2.2Gbps mesh setup and it works great. I am thinking of upgrading to the RBK53 3Gbps mesh system which has a router and 2 satellites. If I do ...
- Dec 21, 2019
Yes, and NO. The existing satellites can be connected to any Orbi router, including the RBR50 and will work just fine. Netgear designed the routers to function ONLY as routers. They can NEVER connect to another router and function as a satellite.
What you CAN do is put the existing router in Access Point (AP) mode (on the advanced tab, advanced setup menu at the bottom). Wire the WAN (yellow) port to the new router and your old router will function as a plain old access point. It is a complicated and messy thing to do and leads to confusion as devices will not "roam" between the Orbi "network" and this isolated access point. The radio channels will conflict. I think that is one reason there are so many Orbi routers for sale on eBay, but almost no satellites.
CrimpOn
Dec 21, 2019Guru - Experienced User
krob3
Thank you for the great info, I really appreciate it!
