Novicefps
Mar 21, 2023Aspirant
Can i use this router without a external antenna
Hello, I have to use an external antenna on the roof with any router I have, if I do not put a antenna on the roof I get 0 mbs ( I get 40 mbs with the antenna on the roof ), so I want to take the a...
Mar 21, 2023Guru - Experienced User
Are you talking like the LBR20?
Its LTE based so if you stuggle to get a LTE signal, it will to.
From the looks of it though, you can add an external antenna to it.
https://www.waveform.com/a/b/guides/hotspots/netgear-orbi-4g-lbr20
then you could use satellites to cover the reset of your home.
but if you're going that route, make sure to buy from somewhere with a generous return policy in case it doesn't work.
- NovicefpsMar 21, 2023AspirantHello.
What I'm looking for really is a router that does not need an broadband antenna on the roof- plemansMar 22, 2023Guru - Experienced User
"Broadband Antenna on the roof"
Doesn't make much sense.
What do you actually have setup for ISP for connections?
Are you trying to get to using LTE hotspots or what's the goal here?
And if you want an LTE hotspot/mesh system, do you have good coverage in your area?
They do work great but only if you have good LTE coverage.
