dissdigg
Mar 18, 2021Aspirant
Can my Orbi RBK50 connect to a switch that is connected to modem ?
Hello and thanks in advance. The issue i am having is that my Orbi mesh rbk50 (router + satellite) for some unknown reason has connection interruptions that last only a brief second but it's enough ...
dissdigg
Mar 19, 2021Aspirant
Sorry for delay, and thanks all for responses.
Hardware: RBR50 (listed this wrong originally, apologies)
Firmware: V2.7.2.104
vajim
Mar 19, 2021Master
dissdigg wrote:Sorry for delay, and thanks all for responses.
lots of discussion about Firmware: V2.7.2.104
you may want to consider rolling it back
- dissdiggMar 19, 2021Aspirant
kindly point me in the direction of the steps to roll it back? at this point it can't hurt as my connections continue to get "interruptions". thanks!
Update: I have optimum coming to install an UBEE modem/router combo that has an internal switch. From here I hope the ability to hard wire work computer directly to modem will prevent the work computer from going offline during these hiccups. My goal would then be to use my ORBI as the router and enjoy the speeds and great range. if the technician at my house won't help with the ORBI side i'll be back to this forum for the great advice you all offer.
If anyone has experience with using the UBEE (UBC1322 or similar) along with the Orbi RBR50 please send me your thoughts. thanks!- vajimMar 19, 2021Master
dissdigg wrote:kindly point me in the direction of the steps to roll it back? at this point it can't hurt as my connections continue to get "interruptions". thanks!
If anyone has experience with using the UBEE (UBC1322 or similar) along with the Orbi RBR50 please send me your thoughts. thanks!go to the download section above here, enter model number
this may help as well:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-RBS50-Cannot-downgrade-firmware/m-p/1836166
