xiaolin
Feb 10, 2019Aspirant
Can Netgear Orbi RBK53. support bandwidth control for guest network ?
I will set up guest network , is it possible to setup bandwidth limit (download bandwidth ) for guest network ? it will use in church, the maximum device connection is about 40-50. and kids connection will be on guest network, we want to limit their download bandwidth.
thanks.xiaolin
1 Reply
Currently there is no bandwidth control in Orbi. I hope it will be coming soon, I think it's a needed feature.
On the other hand you can do the following to limit the kids from using the bandwidth:
- Shut down the 5 GHz band for the Guest network and just keep the 2.4 GHz for the "guests"!
- Block some download services like ftp, but -in Orbi Home- this will affect all devices not only those attached to Guest network only, but is possibel in Orbi Pro
- Block certain sites like Netflix, and other video streaming services, but -in Orbi Home- this will affect all devices not only those attached to Guest network only, but is possibel in Orbi Pro
