Ksa56
Jul 13, 2019Aspirant
can no longer get Netflix or amazon movies Orbi RKB50 using verizon Fios
CrimpOn
Jul 13, 2019Guru - Experienced User
We usually look for "what changed?" For example, Netflix and Amazon movies worked with Fios before installing an Orbi, but do not work after installing the Orbi? Or, they worked before a firmware upgrade but not after? What is being used to view the movies? (TV? Roku? Laptop?, etc.)
How is the Orbi configured? (router? Access Point?)
A number of community members have experience with FIOS, and might be helpful if they know more about the situation.
michaelkenward
Jul 14, 2019Guru - Experienced User
True, but they also need to know about how the FIOS delivers Internet to the user. Probably through some sort of as yet unnamed box from an equally anonymous Internet service provider.
- Ksa56Jul 14, 2019Aspirant
Thank you for responding. I can watch netflix and Amazon on all my computers and ipad. I am trying to watch on 2 roku tvs and one older tv through a 5 or 6 year old Samsung home theatre. The Samsung is what allows me to watch netflix and amazon. Oddly on the Roku tvs I can watch ROKU with no issues. Netflix comes up but with no pictures just empty boxes. when I click on a box it loads to 24% and stops. Amazon comes up like normal but when I try to watch it just goes black and spins. Sometimes on Amazon I get not enough Bandwitch.
- michaelkenwardJul 14, 2019Guru - Experienced User
Smells like a problem with the Samsung.
These things are notoriously troublesome with networking, especially older stuff.
Is that a wifi connection with the Samsung?
You could help by answering the questions that CrimpOn and I have asked.
Yes the samsung is a wifi connection. I figured at first the problem was probably that the Tv was older and so was the Samsung system. But the 2 tvs upstairs are new ROKU tvs and I can not watch either Netlix or amazon on those tvs. Verizon was out a year ago and switched out the fios power box in my house for something newer and my router is from fios less than 2 years old.
