Iansmith01
Dec 19, 2020Aspirant
Can not connect to o2 network, APN issues
i have purchased orbi LBR20 and just to set up and get running i am using a o2 pay as you go data sim, when i enter APN value in the orbi set up app it keeps asking me to check and input again. its ...
Iansmith01
Dec 26, 2020Aspirant
Which APN values did you use for o2 PAYG on this unit. What is power cycling.
thanks.
Jzm2bjo
Jan 07, 2021Initiate
Think it was
Type the following:
APN: payandgo.o2.co.uk
Username: PAYG: payandgo
Password: password
Power cycling = powering off and on, not just a reboot .
Cheers
Type the following:
Password: password
Cheers
