Jiseop
Aug 21, 2020Follower
Can not find rbs
my orbi router can not find rbs
I try everything.. please help me
Sort By
- MstrbigMaster
Need more info.
Is your RBR50 router setup and functing? Did you setup the satellite using the app?
If not, reset the satellite and use the app to add it.
Has a factory reset and setup from scratch been performed since last update?
Use a wired PC and web browser to set up the RBR and RBS.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Jiseop wrote:my orbi router can not find rbs
