Premier79
Jul 05, 2019Tutor
Can not find Router
Recentely just bought the Orbi RBK50 - AC3000. I followed all the steps as listed on the webpage https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite I get up to Step 9, the...
Jul 07, 2019Guru - Experienced User
Factory reset the RBR and connect a wired PC to the RBR and use a web browser to set up the system.
Premier79 wrote:Recentely just bought the Orbi RBK50 - AC3000. I followed all the steps as listed on the webpage https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
I get up to Step 9, the Satellite has a solid blue light. When I go to step 10, connect via wifi on the IPhone app, I receive a message stating "Router not Found." I look at available SSID, looking for mine ORBI63, and it is not listed.
I've redone the steps numerous times with the same results. Any help is appreciated
Hardware
Netgear Orbi RBK50 with Satellite
ISP
Optimum Online
ISP Modem ARRIS TM1602
