Kentthirtys
Mar 20, 2018Follower
Can not have wireless connect between Canon Pixma MG3670 and my new Orbi router
I can not connect the Canon printer MG3670 with the new Orbi router wirelessly. Seems that the printer can't talk with the Orbi router or the router not allow to connect the printer. I did try to use...
- Mar 20, 2018
Make sure your model printer supports WPA or WPA2 with TPIK and or AES security mode. Some older model printers may not support AES. Contact your printer Mfr and ask for help and support about this.
Try setting a static IP address ON the printer for 192.168.1.36 or .70. Ensure Gateway (192.168.1.1) and Subnet Mask (255.255.255.0) are set as well.
If the printer has a LAN port, try connecting it with a ethernet cable.
sh2sg
Mar 20, 2018Apprentice
Mine is Canon MG5670, connects to Satellite (RBS50) with no issue, Canon printer supports 2.4Ghz only.
