Kentthirtys's avatar
Kentthirtys
Follower
Mar 20, 2018
Can not have wireless connect between Canon Pixma MG3670 and my new Orbi router
I can not connect the Canon printer MG3670 with the new Orbi router wirelessly. Seems that the printer can't talk with the Orbi router or the router not allow to connect the printer. I did try to use...
  • FURRYe38's avatar
    Mar 20, 2018
    Make sure your model printer supports WPA or WPA2 with TPIK and or AES security mode. Some older model printers may not support AES. Contact your printer Mfr and ask for help and support about this.
    Try setting a static IP address ON the printer for 192.168.1.36 or .70. Ensure Gateway (192.168.1.1) and Subnet Mask (255.255.255.0) are set as well.
    If the printer has a LAN port, try connecting it with a ethernet cable.
