oscarmatic
Jun 14, 2020Aspirant
Can not SCP using Orbi
Like this comment : ( which I could not figure out how to post/append ) when I use the Orbi regardless of what settings I disable or enable ALL scp copying / transfers fail/stall out. -> scp root@<...
CrimpOn
Jun 14, 2020Guru - Experienced User
Can you please comment on whether Bitdefender Armor or Disney Circle are activated on this Orbi?
- CrimpOnJun 14, 2020Guru - Experienced User
I use WinSCP on my internal LAN which goes through the Orbi,but I have never activated Armor or Circle. Have looked for a "public" SCP server to test, but can find only public SFTP servers.
- Mikey94025Jun 14, 2020Hero
Does it make any difference if you use the -l option to scp and limit the amount of bandwidth grabbed at one time? https://www.unix-ninja.com/p/Why_does_scp_get_stalled_How_do_I_resolve_it
- oscarmaticJun 14, 2020Aspirant
no I can confirm that no arguments or traditional settings in ssh/scp such as -l ( limiting ) or changing MTU or -w net.ipv4.tcp_sack=0
etc changes have an affect and indeed using an alternate AP or direct into ISP modem with same CLI works perfect so the only delta is wifi or lan on orbi, or wifi / lan on another router ( cheaper tlink and an open-wrt router ) .. same test files work great except through ORBI.
Thanks
no bitdefender or parental-controls ( I dont know what disney circle is or where to find it ) but its highly unlikely its enabled or exists.. no childen here, so unless its a default out of the box and hidden somewhere in the UI I have not discovered I do not believe so.
