oscarmatic
Jun 14, 2020Aspirant
Can not SCP using Orbi
Like this comment : ( which I could not figure out how to post/append ) when I use the Orbi regardless of what settings I disable or enable ALL scp copying / transfers fail/stall out. -> scp root@<...
CrimpOn
Jun 14, 2020Guru - Experienced User
Can you please comment on whether Bitdefender Armor or Disney Circle are activated on this Orbi?
oscarmatic
no bitdefender or parental-controls ( I dont know what disney circle is or where to find it ) but its highly unlikely its enabled or exists.. no childen here, so unless its a default out of the box and hidden somewhere in the UI I have not discovered I do not believe so.
