valleynomad
Nov 18, 2021Aspirant
can not telnet RBS40
I have RBS40 converted from RBR40. It runs on V2.5.1.16. which has the option of enbaling telnet access. However, whenever I try to login as admin it keeps asking for correct login credential as if I...
- Nov 18, 2021
You can try the user name "root".
This is sort of uncharted territory. We read comments from users who say they have changed a router into a satellite, but I have never interacted directly with someone who has actually done it. (I certainly have not.) Probably the best move would be to search for specific users who did this hack and ask them.
CrimpOn
Nov 18, 2021Guru - Experienced User
- valleynomadNov 18, 2021Aspirant
"root" works! Thanks!
Then I tried admin and found it somehow worked as well. But the session was ended unexpectely after several minutes.
telnet my RBS40 using root as id is stable.
