abc_pop
Nov 27, 2017Star
Can only choose between 4 channels in 5GHz
I have RBR50 and RBS50 (not proposed in model) Only 4 channelsare available in 5GHz Wifi I'm running in firmware V2.0.0.76 Kindly fit it
Retired_Member
Nov 27, 2017Orbi does not allow you to use DFS channels.
abc_pop
Nov 27, 2017Star
Very disappointing ! For a wifi product !
Could you please explain why Netgear restrict 5GHz to only 4 channels for Orbi
Specially the most used channels
Thanks in advance
- djv323Dec 27, 2017Tutor
Netgear, please answwer. Why only the 4 most used channels for 5ghz??
- RASHID007Jan 12, 2018Guide
Because the other 5Ghz channels are used for the wireless backhaul so you can't use them for your wifi as they'd conflict. The strong dedictated wireless backhaul is one of the main features of the Orbi and reason it performs faster than other mesh systems.
- abc_popJan 12, 2018Star
Thank you Rashid for this clarification.
There are many many channels in 5GHZ available. I'm sure Netgear can block some of them for the wireless backhaul and increase the channels for the user s Wifi
https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_(802.11a/h/j/n/ac)
Many thank to adjust this in the next firmware release
