hn220222
Mar 22, 2019Aspirant
Can Orbi App access to advance setting of Orbi?
Hi,
Can Orbi App access to the advance setting of Orbi? if so, how? I can just access to the basic setting. Can I do port forwarding on the Orbi App?
thanks in advance
- Mar 24, 2019
Hi hn220222
Please use the following reference links :
What functions can I manage using the Orbi app?
How do I enable remote access on my Orbi router using the Orbi app?
Blanca
Community Team
Mar 22, 2019Guru - Experienced User
Any Advanced configurations need to be performed with a web browser and at the routers web pages.
hn220222
Thanks,
then is it possible for me to access the orbi router through internet remotely not through LAN (by web browser not apps)?
- FURRYe38Mar 22, 2019Guru - Experienced User
If you have Remote Management enabled.
- Chuck_MMar 22, 2019Mentor
You can enable remote management by going to your web gui (typically 192.168.1.1) then click ADVANCED tab then click ADVANCED SETUP on left side and then REMOTE MANAGEMENT
Put a check in TURN REMOTE MANAGEMENT ON and pay attention to your remote management address below that.
Note the port number that management is done by and where you can limit who can do remote access.
- Blanca_OMar 24, 2019NETGEAR Employee Retired
Hi hn220222
Blanca
Community Team
- Nyirishman1877Apr 11, 2019Aspirant
How do I access the Adfvance section when it is taking such a long time to appear when I log into the orbi website?
- FURRYe38Apr 11, 2019Guru - Experienced User
Whats condidered a "long time"?
What browser are you using?
