struan99
Sep 05, 2021Tutor
Can Orbi cause problems for Virgin Media SuperHub 3?
Problem: I am using a Virgin Media Superhub 3 in modem mode, connected to a Netgear Orbi RBR50 router. Periodically (sometimes every 5 minutes or so, sometimes once an hour), the Superhub loses its i...
- Sep 06, 2021
I wasn't able to open that spreadsheet (I don't have Excel, and tried in Google Spreadsheets without success). Also, the Superhub 3 lost its connection again this morning while running in router mode and connected to the Orbi. However, I had another (a third!) visit from Virgin Media today. The engineer switched my hub, giving me a Superhub 4 to replace the Superhub 3. When the engineer tried to put that Superhub 4 in modem mode, with the Orbi connected, nothing worked. When he tried putting it in router mode, and disabling wifi via the Superhub 4's control panel, everything did work. I've had a stable connection for the intervening 3 hours or so. I'll cross my fingers that it all continues working, though I'm still baffled as to what went wrong originally, or *why* this approach would work. Thanks for helping me with all this!
struan99
Sep 05, 2021Tutor
Thanks for the reply, but some of this answer doesn't seem relevant to the issue I described. Is my issue familiar? I'm just a bit unclear why I've had good stability for months, then it would drop a week ago; are you sure DMZ mode is the answer here?
struan99
Sep 05, 2021Tutor
Just to answer one question: my Orbi's firmware is V2.7.3.22. I don't think home square footage is relevant to my issue. Thanks!
- CrimpOnSep 05, 2021Guru - Experienced User
Did the issues start when the Orbi firmware was updated to V2.7.3.22?
- struan99Sep 05, 2021Tutor
Hi CrimpOn, that's a good question. I believe the firmware update happened automatically. I didn't take any steps to update it. The problems began on August 25; is there a way to see when my firmware updated to V2.7.3.22? Meanwhile, I've tried your first experiment: I have the Superhub running in router mode, and I've just connected the Orbi, also running in router mode. I'll see how that goes, and then update this thread. If that remains stable, what conclusion should I draw?
There used to be a way to telnet into the Orbi and display the date of last firmware update.
One of the more expert users on the forum created an Exce spreadsheet that displays the date of last firmware update:
https://www.dropbox.com/s/o0eaj5kjs3cpxcc/ORBI%20Soap%20Request.xlsm?dl=0
If you use Excel, download this spreadsheet (icon in upper right of page) and open it with Excel.
Put in the password and then click in the big white box.
I remain mystified how anything that a router does can cause a modem to reboot. Send garbage ethernet packets?
If it were nof for the fact that almost every week someone posts about this happening, I would state that it is impossible.
