hofendis
Nov 21, 2019Aspirant
Can ORBI RBR50 be configured as an access point WIRELESSLY?
I have an RBR50 Router with two satelites. The router is configured in AP mode, using my cable modem/router as the router. To extend the range of my ORBI mesh network, I'm wondering if I can move the...
- Nov 21, 2019
No, the RBR can't wirelessly connect to the ISP Modems wifi. The RBR requires a LAN cable connection to the ISP modem or ONT or LAN interfact with a ISP service or from a router if the RBR is configured for AP mode.
hofendis wrote:Thanks, but not what I meant. If I move the RBR50 across the room, can it pick up its DHCP address from the router wirelessly and work from there as an access point (and connection to the satelites)? Or MUST it be connected via ethernet cable to the router?
Nov 21, 2019Guru - Experienced User
Yes you can move the RBR farther away from the ISP modem. LAN cable lenths come in 50' or 100' lengths. I would start with CAT6 with a 50' lenth cable if this meets your desires between the ISP modem and RBR.
hofendis
- Ragar99Nov 21, 2019Luminary
No, it does not work like that.
- FURRYe38Nov 21, 2019Guru - Experienced User
