debak
Aug 13, 2017Follower
Can Orbi Router connect to existing main router wirelessly in AP mode?
Hi all, I have read about Orbi Router can be switched into AP mode when an ethernet cable is connected from an existing gateway/router to Orbi Router. Will it be possible to achieve this wireles...
st_shaw
Aug 13, 2017Master
No. May be possible if you used some sort of wireless bridge between the Orbi and the router, but it would need to be something that didn't interfere with WiFi.
