HannoosH
Mar 07, 2019Aspirant
can orbi satelite alone works with different router than orbi router?
I just Bought RBK50, it is on the way .. while I was checking I didnt find clear information about the possibility to have the ORBI satelite works without orbi router .
Other products like Noki...
Mar 07, 2019Guru - Experienced User
The one time I tried this, I had my satellited wired to the Orbi base. I removed the base and changed to a different router, leaving the satellite ON and connected via LAN wire to the different router. It continued to. I didn't power OFF and ON the satellite to see if it would operate after that. I presumed it wouldn't as it probably needed to checking with the base that was no longer there. So this portion is not proven.
Other products like Nokia Beacon 3, each unit can work as Satelite and mesh router .
hope that this will be possible .
