HannoosH
Mar 07, 2019Aspirant
can orbi satelite alone works with different router than orbi router?
I just Bought RBK50, it is on the way .. while I was checking I didnt find clear information about the possibility to have the ORBI satelite works without orbi router .
Other products like Noki...
michaelkenward
Mar 08, 2019Guru - Experienced User
The RBK50 is an Orbi kit that comes with an Orbi router (Model RBR50) and an Orbi satellite (Model RBS50).
If that is what you bought, were you planning to use the satellite somewhere else rather than with the router that is also on its way to you?
