bittermanam
Apr 16, 2024Follower
Can Proton VPN be installed on the RBR50 Router
I have an RBR50 router and want to install Proton VPN on it. Proton support said that you can set up a Proton VPN connection on routers that support OpenVPN Client, WireGuard Client, or IKEv2. Does a...
Apr 16, 2024Guru - Experienced User
No.
You can try Voxels 3rd party FW though:
