crvance003's avatar
crvance003
Can RBS50y satellites mesh with each other?
I have a couple of RBS50yv2 outdoor satellites and am trying to use them to provide network coverage from my house down to the bottom of my driveway (around 400 feet). I've configured each to connect...
  • RobertJoseph00's avatar
    Nov 23, 2024
    The RBS50y outdoor satellites cannot mesh directly with each other; they only connect back to the router (RBR50) or indoor satellites (RBS50) in your Orbi system. This limits their effectiveness if placed at intervals along the driveway, as they rely on connecting to the closest device in the network rather than forming a chain. To extend coverage to the bottom of your driveway, try placing one RBS50y where it can receive a strong signal from the router or an indoor satellite, and position the second within the first's range to maintain connectivity. If possible, use Ethernet backhaul to connect the satellites directly to the router or other satellites for better range and stability. Alternatively, consider using directional antennas, third-party extenders, or a dedicated outdoor Wi-Fi system like a point-to-point bridge (e.g., Ubiquiti NanoStations) to cover the 400-foot distance more effectively.
