trashpanda
May 01, 2020Aspirant
Can route to host via wired, but not wireless
I'm running v2.3.5.30. I have 2 NAS boxes in my house in 2 different locations. They are both connected wired back to the Orbi router. When I use a wireless device, I can easily get to one of the ...
CrimpOn
May 01, 2020Guru - Experienced User
How do you connect to the NAS box?
IP address or some sort of "name"?
Web browser? Special software?
"Device" is?
- trashpandaMay 05, 2020Aspirant
The NAS box is a simple Synology NAS that I have configured with a fixed IP address configured in the orbi router static table. When I can't see it... I can't connect via nfs or the web server configured on the box. Ping tells me "request timeout" when I attempt to ping the static ip. I turn off wifi and plug in a hard wired cable... and everything works. Unplug the cable and turn wifi back on... can't find the ip. This occurs from two different devices... though both of them are MacOS ( has occured across siera and catalina )... Even when it can't see the NAS box... it can see the public network with no issue.
