weavernz
Aug 19, 2019Follower
Can someone tell me how to find a return form which was supposed to be attached to an email.
I need to return an Orbi satellite. A form to send with it was supposed to be attached to an email, but wasnt, the form is to be sent back with the defective satellite. Also where do I send the satel...
Aug 19, 2019Guru - Experienced User
Contact the support person whom you had been in contact with.
Check your status here:
https://www.netgear.com/mynetgear/registration/login.aspx
File a support ticket if needed.
