Corradizo's avatar
Corradizo
Can two RBR50 routers function as Router and Satellite?
Hi All,
I just picked up an Orbi RBR50 to see how i like it.  It's great!  I have it in AP mode with my Xfinity modem as the router and its working fine.  I'd like to take the next step and create a mesh network for my home and relegate my Xfinity modem to just being a modem.  While looking at the RBS50 AP's, they are much more expensive than the RBR50 router - more than twice the price!  If I bought another RBR50 could I use it along with my existing RBR50 as Router + Access Point? ie have one RBR50 in Router Mode and the other RBR50 in AP mode?  I have ethernet runs in my home so I can do wired or wireless backhaul, but ultimately would like to keep to one SSID across the house.
Thanks,
Pete
  • Yes, I think you can use the second RBR50 as an AP wired (has to be wired) to the first RBR50 (Router) but you are not getting a mesh system here. The two RBR50's will work independently as a router and AP.
    In the Router-Satellite setup the RBR50 Router is working as a controller for the Satellites to provide you with a mesh network.
    Please note the following:
    - You can use the same SSID on both but you have to select different radio channels on the two base stations.
    - Roaming between the two base stations is much dependent on your devices, Don't expect to get seamless roamings with all devices.
  • FURRYe38's avatar
    RBR units do not support working as a statellite. Only as a main independent wifi router or in AP mode.
    Corradizo wrote:
    Hi All,
    Thanks,
    Pete
  • I definitely want the advantages of the mesh configuration so I'm going to go ahead and pick up the RBS50 to go with my RBR50 router.
    thanks!
    Pete
    • FURRYe38's avatar
      Remember 30 feet is recommended in between Router and satellite to begin with depending upon building materials.
      Enjoy.
      thanks!
      Pete
    • ekhalil's avatar
      ekhalil
      Master
      thanks!
      Pete
      Good choice! :) Good luck..
