jonashlock
May 21, 2023Aspirant
Can you backhaul between two RBS50's via ethernet but not to the router?
I have an ORBI RBR50 with 2 RBS50's. In the house we have great service but our detached garage is hit and miss. To fix I undergrounded a cat 6 cable in hopes I could backhaul to the router.
My bad to not look at how to configure it before. I thought the router was in my wifes office (closest to the garage) but it is actually on the other side of the house and all its wired ports are currently in use with other devices. (moving the router is not an option)
Is it possible to backhaul from a satellite to a satellite? All the diagrams show making a daisychain to the router. I don't want to cut holes in the walls to route wires if satellite to satelite won't work.
I've seen it done on here. I've never personally done it.
- jonashlockAspirant
Thank you Fury.. I found that also. What I am wondering is if I can backhaul wired to a sattelite to a sattelite that is wirelessly connected to the router.
Yes. That should work.
