sandman512
Mar 01, 2020Apprentice
Can you force a device to the router or one of the satellites?
So, I own the RBR50 Mesh system with two satellite. I had to move one of the satellites from the basement to my garage(ORBI 2) for better coverage. I noticed that every device is either connected t...
Mar 02, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Turn down the power output onf the RBR from 100% to say 50%. This will help with where devices connect too. Under Advanced Tab/Advanced Settings/Wireless Settings
It's up to device to pick and choose on where to connect, not Orbi.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sandman512 wrote:So, I own the RBR50 Mesh system with two satellite. I had to move one of the satellites from the basement to my garage(ORBI 2) for better coverage. I noticed that every device is either connected to the router or the ORBI . I am assuming that when I took ORBI 2 from the basement and moved it to the garage everyting found another connection. So, my question is is there a way to "force" a device to a connect to the router or the satellites? Thanks you!
