VerneArase
Jan 12, 2020Apprentice
Can you restore a config from an RBR50?
Just curious if it's possible to restore an RBK50 config to the new models. I put in a feature request a long time ago to allow config to carry over from model to model as basically you have to g...
CrimpOn
Jan 13, 2020Guru - Experienced User
I interpreted the question to mean "can I take a configuration file from one model of Orbi and use it to configure a different model, such as an RBR20 or one of the AX models?" I also rely one the config file from one RBR50 working on other RBR50s, but doubt that it can be used on other models. Certainly would be useful.
Yes, a 50 series backup file can't be used on 20 or 40 series systems and vs versa. Backup files are used with in there own specific model fields.
