VerneArase
Jan 12, 2020Apprentice
Can you restore a config from an RBR50?
Just curious if it's possible to restore an RBK50 config to the new models. I put in a feature request a long time ago to allow config to carry over from model to model as basically you have to g...
VerneArase
Jan 21, 2020Apprentice
Huh ... how do you get a telnet session? I do a:
20.01.21 07:07:54 Host: Verne-iMac5K, ID: varase, Num: 6, Hist: 322, RC: 0 [~] % nmap 192.168.1.1
Starting Nmap 7.80 ( https://nmap.org ) at 2020-01-21 07:10 CST
Nmap scan report for 192.168.1.1
Host is up (0.0078s latency).
Not shown: 990 closed ports
PORT STATE SERVICE
21/tcp filtered ftp
80/tcp open http
443/tcp open https
631/tcp open ipp
3333/tcp open dec-notes
4444/tcp open krb524
4567/tcp open tram
5555/tcp open freeciv
20005/tcp open btx
49152/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 1.33 seconds
and I don't see port 23 open.
Is there an option to open a command line interface?
CrimpOn
Jan 21, 2020Guru - Experienced User
VerneArase wrote:Huh ... how do you get a telnet session? I do a:
Port 23 (telnet) is not open by default. (Do not want people hacking the system.) Open the Orbi "debug" page, http://192.168.1.1/debug.htm and log in using the admin credentials, "admin" and password. Check the box, "Enable Telnet".
(Note: the telnet port remains open for quite some time, but eventually Orbi will close it again. You will go to the web page and even though the box is checked, it will not respond. Uncheck the box. Wait for web page to reload. Check box again, and telnet is open again.
