mrm18
May 26, 2020Tutor
Can you tell if Orbi satalite is connected without doing a resync
Is there a way to check if my satallite is connected without donig a resync? I have a RBR50 router and 2 RBS 50 (one was recently added)
1 Reply
There are two easy ways:
- Open the Orbi web interface (http://orbilogin.net) and look at the Attach Devices page.
Satellites appear in a section at the top. - Power the satellite off and back on again.
The "ring light" at the top will go through several steps.
If you see a BLUE light for 70-120 seconds, that means it is connected and has a good signal.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
