VerneArase
Sep 08, 2019Apprentice
Can you use manual DNS while getting dynamic IP address from provider?
I can't seem to set the DNS address which will be used by my network. Is a manual DNS address verboten if you're getting your router's IP address via DHCP?
ekhalil
Sep 08, 2019Master
Yes, you can select manual DNS regardless if you have static or dynamic IP address.
This can be set under >> ADVANCED >> Setup >> Internet Setup
VerneArase
ekhalil wrote:Yes, you can select manual DNS regardless if you have static or dynamic IP address.
Except it won't let me choose "Use These DNS Servers".
In fact, the only way I can get it to allow that choice is if I choose "Use Static IP Address".
- CrimpOnSep 08, 2019Guru - Experienced User
This has become a frequent question lately. What we seem to find is that customers who activate Disney Circle or Armor find that they no longer get to define custom DNS servers. Would you by chance have activated either of these?
- VerneAraseOct 14, 2019Apprentice
Yes, both actually.
- CrimpOnOct 14, 2019Guru - Experienced User
Well (sigh) this appear to be your situation. As I recall, one user was able to turn off Disney Circle, set custom DNS entries, and then turn Circle back on again. (Search the forum posts for DNS)
