VerneArase
Sep 08, 2019Apprentice
Can you use manual DNS while getting dynamic IP address from provider?
I can't seem to set the DNS address which will be used by my network. Is a manual DNS address verboten if you're getting your router's IP address via DHCP?
VerneArase
Oct 14, 2019Apprentice
Yes, both actually.
CrimpOn
Oct 14, 2019Guru - Experienced User
Well (sigh) this appear to be your situation. As I recall, one user was able to turn off Disney Circle, set custom DNS entries, and then turn Circle back on again. (Search the forum posts for DNS)
- browncowJan 01, 2020Initiate
Worked for me, thanks for the tip.
- Went to Basic -> Parental Controls
- Toggled Circle from Enabled to Disabled
- Went to Advanced -> Internet
- Left Internet IP Address set to Get Dynamically from ISP
- Set DNS Address to Use These DNS Servers and entered my custom servers
- Apply to save the changes
- Went back to Basic -> Parental Controls
- Toggled Circle from Disabled to Enabled
Now I have custom DNS servers set with Circle parental controls enabled.
- AMG1978Mar 24, 2020Tutor
I never would have thought about Circles. I turned it on and never used it. Lately my ISP has had issues with their DNS servers and while I can manually modify them in Windows for the adapter, that isnt the ideal solution. So I decided to try to change it on the Orbi and same issue you had. After disabling Circles, I can manually set to google's 8.8.8.8 and 8.8.4.4
Thank you for posting a spot on solution.
- VerneAraseSep 18, 2020Apprentice
I use Cloudflare's 1.1.1.1.
Cloudflare's less data hungry - more internet infrastructure minded.
I shudder to think how Google may see this a data harvesting opportunity.
