VerneArase
Sep 08, 2019Apprentice
Can you use manual DNS while getting dynamic IP address from provider?
I can't seem to set the DNS address which will be used by my network. Is a manual DNS address verboten if you're getting your router's IP address via DHCP?
Mstrbig
Sep 18, 2020Master
VerneArase wrote:I can't seem to set the DNS address which will be used by my network.
go to orbilogin.com > Internet
Check "Use These DNS Servers" and choose the DNS servers you prefer.
- VerneAraseSep 18, 2020Apprentice
Must've been Disney Circle which was disabling the setting, since I've got Armor on my RBK853 and I can set a DNS address - or maybe things were different on the RBK53 than on the RBK853.
- FURRYe38Sep 18, 2020Guru - Experienced User
When Circle is enabled on the 50 series, this disable the DNS configuration page. :smileywink:
