rcsmhkb
Jun 19, 2019Aspirant
Canada Telus Router & Orbi RBK23
I'm in Canada and using Telus 750 fibre, when i install Orbi, i connect with lan cable to telus router. So my home has 2 router. Telus router has assign ip 10.0.0.5 to Orbi. I have problem to login ...
Jun 19, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
