rcsmhkb
Jun 19, 2019Aspirant
Canada Telus Router & Orbi RBK23
I'm in Canada and using Telus 750 fibre, when i install Orbi, i connect with lan cable to telus router. So my home has 2 router. Telus router has assign ip 10.0.0.5 to Orbi. I have problem to login ...
CrimpOn
Jun 19, 2019Guru - Experienced User
It might be useful to call Telus and inquire about putting their equipment in bridge mode. Earlier models of Telus routers had the capability. Found this on Google:
- rcsmhkbJun 19, 2019Aspirant
i have tried to changed telus router to bridge mode just now. the orbi router setting remain unchange but orbi still receive 10.0.0.5 as the ip address. When i setup orbi before should alreday set as router mode. Is there any other setting i need to do ? Tks.
- CrimpOnJun 19, 2019Guru - Experienced User
So, Telus showed you how to log into the router and change the mode? Great!
It is probably necessary to restart both the Telus and the Orbi. If Telus is really in bridge mode, the Orbi should get a "public" IP address.
Is telnet Client check-marked in "Programs & Features" under "Turn Windows features on or off"?
