rcsmhkb
Jun 19, 2019Aspirant
Canada Telus Router & Orbi RBK23
I'm in Canada and using Telus 750 fibre, when i install Orbi, i connect with lan cable to telus router. So my home has 2 router. Telus router has assign ip 10.0.0.5 to Orbi. I have problem to login ...
CrimpOn
Jun 19, 2019Guru - Experienced User
It might be useful to call Telus and inquire about putting their equipment in bridge mode. Earlier models of Telus routers had the capability. Found this on Google:
rcsmhkb
i have tried to changed telus router to bridge mode just now. the orbi router setting remain unchange but orbi still receive 10.0.0.5 as the ip address. When i setup orbi before should alreday set as router mode. Is there any other setting i need to do ? Tks.
- CrimpOnJun 19, 2019Guru - Experienced User
So, Telus showed you how to log into the router and change the mode? Great!
It is probably necessary to restart both the Telus and the Orbi. If Telus is really in bridge mode, the Orbi should get a "public" IP address.
Is telnet Client check-marked in "Programs & Features" under "Turn Windows features on or off"?
oops. Sorry. wrong post. "My Bad"
- rcsmhkbJun 19, 2019Aspirant
i can see the telus provide a public ip to orbi, but when i go to orbi setting, it still using 10.0.0.1 as ip address. pls see the photo to see if any clue to fix it.
screen capture of orbi setting
- michaelkenwardJun 20, 2019Guru - Experienced User
And you have to restart things in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
It may help to reset the RBR20, the RBK23's router, before doing this.
