rcsmhkb
Jun 19, 2019Aspirant
Canada Telus Router & Orbi RBK23
I'm in Canada and using Telus 750 fibre, when i install Orbi, i connect with lan cable to telus router. So my home has 2 router. Telus router has assign ip 10.0.0.5 to Orbi. I have problem to login ...
rcsmhkb
i have tried to changed telus router to bridge mode just now. the orbi router setting remain unchange but orbi still receive 10.0.0.5 as the ip address. When i setup orbi before should alreday set as router mode. Is there any other setting i need to do ? Tks.
CrimpOn
Jun 19, 2019Guru - Experienced User
So, Telus showed you how to log into the router and change the mode? Great!
It is probably necessary to restart both the Telus and the Orbi. If Telus is really in bridge mode, the Orbi should get a "public" IP address.
- CrimpOnJun 19, 2019Guru - Experienced User
Is telnet Client check-marked in "Programs & Features" under "Turn Windows features on or off"?
oops. Sorry. wrong post. "My Bad"
- rcsmhkbJun 19, 2019Aspirant
i can see the telus provide a public ip to orbi, but when i go to orbi setting, it still using 10.0.0.1 as ip address. pls see the photo to see if any clue to fix it.
screen capture of orbi setting
Oh, dear. The Telus is "routing", not in bridge (or "pass thru") mode. There are two "private" IP address spaces: 192.168.x.x and 10.0.x.x
The Orbi used DHCP to ask, "what's my IP address", and the Telus said, "your IP is 192.168.1.65". The Orbi said, "well, shucks, the 192.168 private address space is already in use, so I will assign all of MY devices addresses in the 10.0 space."
Since you are able to log into the Telus router, maybe there is a menu setting to put it into bridge mode.
The other option is to put the Orbi into Access Point (AP) mode, and find some way to get the Telus to support TeamViewer.
- FURRYe38Jun 20, 2019Guru - Experienced User
You man manually change that IP address to what ever you like, so if you want to use 192.168.1.1 you can manually change it to that IP address. I recommend changing the pool size to 192.168.1.100 to 192.168.1.200.
Should be found under Advanced Tab/Setup/LAN setup.
rcsmhkb wrote:i can see the telus provide a public ip to orbi, but when i go to orbi setting, it still using 10.0.0.1 as ip address. pls see the photo to see if any clue to fix it.
- CrimpOnJun 20, 2019Guru - Experienced User
The Orbi was given IP address 192.168.1.65 by the Telus router, which means that the Telus is using DHCP to assign addresses in the 192.168.1.x range. Since the goal is to get TeamViewer working, perhaps the task at hand is to get rid of the "double NAT" situation. Although Telus gave instructions for putting the Telus into bridge mode, it appears that it remains a router.
I have no idea what TeamViewer requires from a router to operate correctly, but it is pretty clear that one of the devices needs to quit being a router.
Given that the Telus remains a router, my next step would be to put the Orbi into AP mode and see if that permits TeamViewer to work. If that is successful, then the question is whether the Telus router functions are "enough" or if there is reason to return the Orbi to working as a router and try again to put the Telus into bridge mode. This test requires nothing of Telus support and can be done (relatively) quickly.
If TeamView still does not work, then there is some router setting that is required, and the next step is to (a) figure out what it is, and (b) determine whether the Telus or the Orbi can be set up to handle it.
- michaelkenwardJun 20, 2019Guru - Experienced User
And you have to restart things in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
It may help to reset the RBR20, the RBK23's router, before doing this.
