dmy0603
Jun 27, 2018Follower
Cannot access QNAP TS-251+ NAS using hostname over WiFi. (hostname only recognized when hard-wired)
Orbi RBK53 / Firmware v2.1.4.16
I have a QNAP TS-251+ NAS on my home network. I am trying to access this NAS device from a Windows 10 laptop. I have determined I can only access the NAS using it's host name if the laptop is hard-wired to the network. If the laptop is connected via WiFi, I can only access the NAS using the IP address.
Using the same Win10 laptop, I can successfully access a Win7 PC on my home network using the host name whether hard-wired or via WiFi. Am I wrong in expecting to be able to access this NAS device over WiFi via host name, the same as with the home PC? Both the home PC and NAS are directly hard wired to the RBR50 router.
1 Reply
I would ask QNAP about this host name problem. If you can connect using host name to Windows 7 PC and you can with QNAP, Something either on Windows 10 PC or NAS.
