dtskip's avatar
dtskip
Guide
May 15, 2021
Cannot access self-hosted domains after updating to V2.7.2.104
I self-host a Nextcloud server among other things on a domain I purchased. But since updating my Orbi from V2.5.1.16 to V2.7.2.104, those domains simply do not load anymore, unless I connect to a VPN. They work fine from outside the network, but not from within my own network. What gives?
I can only conclude this is a problem from the Orbi, but have no idea where I should be looking.
    • dtskip's avatar
      dtskip
      Guide
      FURRYe38 wrote:
      Revert back to v16?
      Not an option. I had enough trouble with the last nightmare of downgrading firmware. It just goes into an endless loop of "Please wait" when trying to downgrade the router.
  • CrimpOn's avatar
    CrimpOn
    Have you tried connecting using the Orbi public IP address, rather than the Domain Name?
    • dtskip's avatar
      dtskip
      Guide
      Yes, and it works with some of my docker containers, but not Nextcloud, which always redirects to the domain. That's how I prefer it too, so I only have to connect to a single domain whether I'm connected to my home network or not.
      I want to find the problem this firmware update caused which seems to be blocking my personal domain.
      • CrimpOn's avatar
        CrimpOn
        I am struggling to come up with an experiment to reproduce the issue.  Probably because of not understanding how NextCloud and "domains" work.  (one sentence said "domain I purchased" and another said "those domains".  Are there more than one domain?
         I found this guide on running NextCloud:
        https://docs.nextcloudpi.com/en/how-to-access-from-outside-your-network/
        Is this even close to what is going on:
        • There is a Linux server on the local network running NextCloud, which listens for connections on ports 80 and 443.
        • On the Orbi router, ports 80 and 443 are forwarded to the server
        • At either My-IP.com or Dyn.com a domain name is associated with the public IP of the Orbi.
          (I sense a potential issue here because Orbi's DDNS works with either My-IP.com or Dyn.com and NextCloud talks about using either My-IP.com or FREEDNS.  Which are you using?)
        I seem to recall there being issues with forwarding port 443 through the Orbi.  (Probably not remembering correctly.)
