Babinator
Jan 23, 2020Aspirant
Cannot access websites
I cannot access websites. It's not always consistent, either. For example, I get a message like this:
http://ereader.wsj.net is requesting your username and password. The site says "NETGEAR Orbi" and has spaces for User Name and Password.
- BabinatorAspirant
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - michaelkenwardGuru - Experienced User
What with? A browser? Which one? On what? A Windows PC? iOS tablet? Something else?
Any Progess on this?
Babinator wrote:I cannot access websites. It's not always consistent, either. For example, I get a message like this:
