macphreak
Oct 14, 2019Guide
Cannot access Xfinity App or oauth.xfinity.com
I have the ORBI RBR40 Router and recently it stopped allowing me to access my Xfinity apps (or more specifically, oauth.xfinity.com). I am unable to login to my xfinity account online and not able to...
macphreak
Oct 14, 2019Guide
I just tried your suggestion. That didn't work either (I thought that was a good suggestion though!)
I went over to that other forum and searched for Xfinity. Sure enough, there are other people with this exact same issue. I posted the same question there. I will see what they say and see if the issue can get resolved. Thanks for all your help!
Heartless274
Jan 26, 2020Initiate
Has this issue ever been resolved? I reset my Orbi/Satellite a few months ago to fix this issue with connecting to oauth.xfinity.com which is an HTTPS site. I even updated my advanced settings to prevent HTTS from being blocked. I still have issues connecting for paying bills or when Showtime Anytime wants me to update my credentials to keep being able to use it. I have to use my mobile phone anytime I want to do anything related to Xfinity account services because of this glitch.
I really really really don't want to keep resetting the router just to access this site.
- FURRYe38Jan 27, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Heartless274 wrote:Has this issue ever been resolved? I reset my Orbi/Satellite a few months ago to fix this issue with connecting to oauth.xfinity.com which is an HTTPS site. I even updated my advanced settings to prevent HTTS from being blocked. I still have issues connecting for paying bills or when Showtime Anytime wants me to update my credentials to keep being able to use it. I have to use my mobile phone anytime I want to do anything related to Xfinity account services because of this glitch.
- macphreakJan 28, 2020Guide
This has nothing to do with the Modem and Bridge mode. I have a Arliss modem (not an Xfinity modem) and I *still* am unable to login to the Xfinity site. Only when I use my LTE data connection through my phone or iPad then I can login just fine.
I also created a hot spot on my phone and test the LTE hot spot and it worked on my desktop as well. It is only when I use the Orbi router do I run into this issue. And this issue only started after I tried the "Armour" trial (if anyone is reading this - DO NOT try the Netgear Armor trial. It really messes up your router majorly).
Why can't Netgear get this fixed? This has been an ongoing issue for months now with no resolution other than "reset".
- FURRYe38Jan 28, 2020Guru - Experienced User
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armorGood Luck.
I have posted there as well. Nothing has yet to be done from Netgear.
You'll have to keep on it. Contact one of the forum moderators awell.
- meh7777Jun 01, 2020Aspirant
I'm having this same problem. Just started this morning. what is the resolution. I can't reach https://oauth.xfinity.com/oauth/authorize
- CrimpOnJun 01, 2020Guru - Experienced User
This particular Netgear community forum attracts customers who have the residential WiFi Orbi mesh systems. There is another forum for the Nighthawk line of WiFi routers.
If the problem began today and nothing has changed in regard to the WiFi router (C7100v), then the problem is unlikely to relate to the router. Surely in the past several months the Xfinity help line must have dealt with many customers who have this problem.
What do they say?
- jlnesheimJul 14, 2020Aspirant
Has this issue been resolved? I cannot access xfinity.com or login to my account.
- FURRYe38Jul 14, 2020Guru - Experienced User
What is the mfr and model of your router? IF this is regarding the C7100v cable gateway, please post about this in the cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
jlnesheim wrote:Has this issue been resolved? I cannot access xfinity.com or login to my account.
Resolved issue by restarting Netgear modem - then going to Incognito/Private browser pages in Firefox then Safari, then normal pages in both, then to normal page in Chrome. Weird but it worked. Someone at Netgear tech staff needs help. Thanks for your reply.
Please post what model# NG product you have.
This is a Orbi AC wifi mesh systems forum.
Please post in the correct forum for your modem if its a NG modem.
Good Luck.
jlnesheim wrote:Resolved issue by restarting Netgear modem - then going to Incognito/Private browser pages in Firefox then Safari, then normal pages in both, then to normal page in Chrome. Weird but it worked. Someone at Netgear tech staff needs help. Thanks for your reply.
