lasttime
Sep 26, 2020Aspirant
Cannot achieve fiber speeds RBR50 with Centrylink Fiber
Hello, With the C4000gx and a direct connection i get full gigabit speed (900+ up and down). With the Orbi in AP mode and connected to the C4000gx, I get full gigabit speed from the speed test d...
Mikey94025
Sep 29, 2020Hero
lasttime wrote:However, when I remove the C4000gx and directly connect the Orbi to the fiber, I get half to 1/3rd the speeds I was getting. Less than 400up, and maybe 300 down. Is there a way to get the Orbi to get the speeds from fiber, or is it too slow to handle being both the modem and the router at the same time?
It sounds like this C4000gx is your router and you're asking if you can run the Orbi instead for routing (you don't seem to need a mode). The Orbi should, many of us use our Orbi as the router and get close to gigabit speeds (wired).
Does this FAQ help? https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/td-p/1982974
