darckhart
Jun 21, 2018Aspirant
cannot block sites when on ssl. is this feature useless now?
I recently upgraded to the Orbi from the Nighthawk and, after making sure things were working, decided to see if I could start blocking some sites. (Upon logging into the router, I go to Advanced, Se...
Jul 04, 2018Guru - Experienced User
Did blocking SSL sites work on your Nighthawk router?
Seems that SSL sites are usually not blocked on routers. You may need to sign up for a DDNS service and point your router to this service, then use this service to block SSL sites...
- alexandermgNov 23, 2018Aspirant
Extremely frustrating... it seems the ability to block individual websites at the router level is not possible. I've been trying to block a few websites just to test it out- it's a joke! Sometimes they do get blocked, but if you do a google search for the website you're trying to block and click it from there it goes right through. Chrome seems to bypass it like it's not even there. Come on NETGEAR!!!!! Get it together!
- FURRYe38Nov 24, 2018Guru - Experienced User
Seems that SSL sites are usually not blocked on routers. You may need to sign up for a DDNS service and point your router to this service, then use this service to block SSL sites...Seen with eith other router Mfrs.
