Retired_Member
Aug 03, 2017Cannot configure parental controls
Firstly I have to say that I'm fatigued with the constant stream of issues I've had with my Orbi over the last few months. No premium device should suffer this many problems. The flakiness of the fir...
- Retired_MemberSep 25, 2017
Apparently v2.0.0.74 fixes this. I installed it this weekend and did a factory reset. I've setup Parental Controls and so far, so good. The problem did usually take a few days to appear so I'm keeping my fingers crossed.
chanklb
Sep 24, 2017Aspirant
I have the same problem. Deleted my ID from OpenDNS and tried again. No luck.
I was able to setup it up in July when I first got the Orbi.
- chanklbSep 25, 2017Aspirant
Thanks! I first tried upgrading the firmware to v2.0.0.74, power cycling the Orbi and Satellite. No change of the behaviour. I had to perform a factory reset to make it work again. By the way, I tried restoring the config from a backup I took right before the reset. It "restored" the problem symptom too. Let's see how it goes.
- chanklbSep 25, 2017AspirantBTW did you try the device level control and the bypass login? I cannot get the bypass login work.
