nicol117
May 29, 2017Follower
cannot connect a new laptop wirelessly even with correct password
hi i just got a new msi gaming laptop and even though it recognises orbi wifi i cant connect even after it asks for password and i enter correctly says not allowed what am i doing wrong i hav...
TheEther
May 29, 2017Guru
Do you have MAC address control enabled on the Orbi? If yes, then you need to unblock your laptop's MAC address on the Orbi. Check the logs on the Orbi while you're at it.
