JArcher
Jan 27, 2019Aspirant
Cannot connect Iphone XR to RBR40
Hi,
I have an Iphone XR that cannot connect to an Orbi AC2200 - just tries to connect and it would not connect and would not give any errors. I have multiple devices that I can sucessfully co...
michaelkenward
Jan 28, 2019Guru - Experienced User
JArcher wrote:
Hi,
I have an Iphone XR that cannot connect to an Orbi AC2200 - just tries to connect and it would not connect and would not give any errors. I have multiple devices that I can sucessfully connect (other apple iphones).
Sort of points at the Iphone XR as the source of the problem. Your router does not care about what you throw at it.
What happens when you try to connect? Any error messages?
- JArcherApr 19, 2019Aspirant
Hi
Thanks for your response. It does not give any messages. It connects (sometimes) but there is no internet connectivy
Thanks for your help
- FURRYe38Apr 22, 2019Guru - Experienced User
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307. Changed preamble modes to long or short
JArcher wrote:
Hi
preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
