MrBlue13
Apr 01, 2021Aspirant
Cannot connect mesh ac1200 to hitron teksavvy hitron coda-45 modem
Hi there, I can't seem to connect the NETGEAR Orbi AC1200 Whole Home Mesh Wi-Fi 5 System to my ISP teksavvy modem Hitron coda-45. Connected the lan1 port on modem to internet port on the orbi but g...
- Apr 02, 2021
Wanted to add that you did exactly what we advice people to do: test the modem connection.
It would probably be a good idea to "double check" the modem by turning it off, waiting 30 seconds, turning it back on, and try plugging in the laptop again. (That's the step I seem to omit too often. "If in doubt, restart it.")
CrimpOn
Apr 01, 2021Guru - Experienced User
MrBlue13 wrote:
Hi there,
I can't seem to connect the NETGEAR Orbi AC1200 Whole Home Mesh Wi-Fi 5 System to my ISP teksavvy modem Hitron coda-45. Connected the lan1 port on modem to internet port on the orbi but going through the Netgear orbi android app setup, it can never find a network connection. Internet connection from same port to laptop works fine. Reset each device multiple times, any ideas? Thx
AC1200 is an artificial number that is supposed to (in some way) represent "speed". What is the product model number (from the label on the bottom of the router)?
Does the Orbi "app" locate the Orbi router?
