MrBlue13's avatar
MrBlue13
Cannot connect mesh ac1200 to hitron teksavvy hitron coda-45 modem
Hi there, I can't seem to connect the NETGEAR Orbi AC1200 Whole Home Mesh Wi-Fi 5 System to my ISP teksavvy modem Hitron coda-45. Connected the lan1 port on modem to internet port on the orbi but g...
  • CrimpOn's avatar
    CrimpOn
    Apr 02, 2021
    Wanted to add that you did exactly what we advice people to do: test the modem connection.
    It would probably be a good idea to "double check" the modem by turning it off, waiting 30 seconds, turning it back on, and try plugging in the laptop again. (That's the step I seem to omit too often. "If in doubt, restart it.")
