MrBlue13
Apr 01, 2021Aspirant
Cannot connect mesh ac1200 to hitron teksavvy hitron coda-45 modem
Hi there, I can't seem to connect the NETGEAR Orbi AC1200 Whole Home Mesh Wi-Fi 5 System to my ISP teksavvy modem Hitron coda-45. Connected the lan1 port on modem to internet port on the orbi but g...
- Apr 02, 2021
Wanted to add that you did exactly what we advice people to do: test the modem connection.
It would probably be a good idea to "double check" the modem by turning it off, waiting 30 seconds, turning it back on, and try plugging in the laptop again. (That's the step I seem to omit too often. "If in doubt, restart it.")
CrimpOn
Apr 02, 2021Guru - Experienced User
MrBlue13
Apr 02, 2021Aspirant
Ok thanks for reply. When I manually set ip address to 192.168.1.110, in the range modem suggests, I can connect to the gateway admin page from pc, but there is no internet. Looks like it's a bridged modem. When I set obtain automatically on PC, internet works but I can't access modem admin page. Not sure why modem won't assign IP.
I called the ISP and they said since internet works when connecting PC to modem, orbi should work. It did work with the older modem they gave me, just not this new one. So I know orbi works.
I'll try the reset again, but running out of options, not sure new option is to get another modem.
- MrBlue13Apr 02, 2021AspirantOk finally working! With one more attempt and more patience, the reset of both devices, unplug all ethernet and coaxle and waiting few minutes, orbi has found its way. Thx for help.
